12-27-2024, 11:17 AM
Good afternoon,
I flashed several times the KC868-A16S board with ESPHome firmware but the relay n. 8 remains always in on state (also the status led on the board) and it is impossible to control it.
This is the last firmware (still with the problem) :
Can You help me ?
friendly_name: Centralina citofono
encryption:
key: "E3acLht11PoN5oLlgBJPgIO/+elvX80lTzGbQPfVnH8="
ota:
- platform: esphome
password: "0b4d665617eac63f109a0dd7b51a409e"
sda: 4
scl: 5
# Example configuration entry
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
- id: 'pcf8574_hub_out_2' # for output channel 9-16
address: 0x25
address: 0x23
# Individual outputs
pcf8574: pcf8574_hub_out_1
mode:
output: true
pcf8574: pcf8574_hub_out_2
- platform: restart
name: EspHome Node Restart
pcf8574: pcf8574_hub_in_2
inverted: trueCan You help me ?
