Full Version: KC868 A16 mqtt temperature sensor - home assistant
My gear: KC868 A16, KCS
DS18B20 connected to chanel 1
I have one DS18B20 connected to chanel 1, and its working correct. I see that temperature is changing through kcs panel
[attachment=6788]>
Unfortunately looks like temperature value is not provided by mqtt. Through mqtt explorer i see there is only two threshold values provided by mqtt.
[attachment=6789]
what KCS firmware version you are using?
V2.2.8 I think it's most actual?
i think you have not set the mqtt "Threshold" value for your sensor. here is tested image with KCS v2.2.10.
[attachment=6820]
[attachment=6821]
[attachment=6822]
[attachment=6823]
Yes, it works now!
I don't think I understand what this threshold means and what it's for, that's why I left 0. Could you explain what this means?
Thanks in advance!
If this difference is exceeded, mqtt will automatically report data. Avoid frequent data reporting that generates a large amount of data traffic
