Full Version: "KCS" v2.2.10 firmware BIN file download
Pages: 1 2 3 4
v2.2.10 improvement:
1. Fix the problem that multiple DI false configurations in ifttt cannot work well.
2. Fix the problem that ifttt processing will be blocked when mqtt is disconnected
UTC time setting and display on `index.html` page is still broken.
I have 2 new KC868_A16 boards and each have a different, *wrong* calculation for UTC-N time offsets.
Specifically,
- On one board, UTC-N gives UTC-(N+1). E.g., I am in Americas/New_York which is now on EST which is UTC-5 but when set to UTC-5, the time reads as UTC-4
- On another board, UTC-N give UTC-(N-8). E.g., I am in Americas/New_York which is now on EST which is UTC-5 but when set to UTC-5, the time reads as UTC-13
Also the display of time (under `index.html`) is non-standard. Specifically, it doesn't force 2 digits for the display of seconds, minutes (or hours).
For example: 4:07:05 reads as: 4:7:5 which is totally non-standard.
This should be a pretty simple bug in the code to correct as it just requires the correct arithmetic to add/subtract from UTC hours plus the correct formatting of the time printout.
Note I am using FW 2.2.10
UTC issue will fix in next update version.
Hello, are there any plans to prepare software for the M16 board?
HI EVERYONE, I'M LOOKING FOR THE LATEST FIRMWARE FOR THE KC868_A24 BOARD, CAN ANYONE HELP ME?
(01-10-2025, 09:20 AM)105Timi Wrote: [ -> ]Hello, are there any plans to prepare software for the M16 board?
no this plan, develop firmware based on M30 series.
here is A24 firmware:[attachment=6850]
(01-11-2025, 01:32 AM)admin Wrote: [ -> ]
Will it be possible to use it with M16 inserts?
(01-11-2025, 09:28 AM)105Timi Wrote: [ -> ]
no, can't .
Pages: 1 2 3 4
