Full Version: PWM output
It is possible to do PWM to working with motor and PWM ,
If yes in which voltage?
If no what about the ads1115 it can be config as output or input it possible?
TurSolution
ads1115 use for analog input, can't work for output.
you can try to define free gpios work with PWM output, if you will write your own arduino code.
or you can config PWM by esphome, details at here: https://esphome.io/components/output/esp8266_pwm.html
(12-29-2024, 10:18 PM)admin Wrote: [ -> ]ads1115 use for analog input, can't work for output.
Can you tell mw which pins are there? which numbers?
there are SDA,SCL i2c bus extender terminal. you can check with B16M shell's label.
