01-27-2025, 09:04 PM
I am using ESPHome and I am seeing a lot of problems with the floating input. Can someone tell me if I can specify pullup? I tried with esphome normally and it doesn't like it so I am stuck?
(01-28-2025, 01:01 AM)admin Wrote: [ -> ]![]()
see this photo. S1, S2, S3, S4 ports all have pull up resistance on PCB.
(01-28-2025, 01:15 AM)heffneil Wrote: [ -> ](01-28-2025, 01:01 AM)admin Wrote: [ -> ]![]()
But I am using the inputs on the top left ground to input off the one chip
[color=oklab(0.89908 -0.00192907 -0.0048306)] - platform: gpio
name: "Water Closet Door Sensor"
filters:
- delayed_on: 0.5s[/color]
Do these have pull up resistors? I am seeing significant bouncing?
(01-28-2025, 01:30 PM)admin Wrote: [ -> ](01-28-2025, 01:15 AM)heffneil Wrote: [ -> ](01-28-2025, 01:01 AM)admin Wrote: [ -> ]![]()
filters:
these port can't use pull up resistor. they are not connect with ESP32 pin directly. i suggest you test with S1,S2,S3 or S4 port.
