Full Version: Interfacing WS2812B led strips
Hi I am using KC868 AIO installed for my smart home project, I would like to interface 4 ws2812b led strips how can I do that? Which of the pins can be used as data pins for the same. An example circuit and Yaml also will be appreciated.
Regards
Krushi
GPIO5 and GPIO14 can use for ws2812b. there is free gpio terminal you can use it.
I would like to connect 4 independent Led strips for different locations, so I might need more than 2 pins. Are there any more pins that I can use for other led strips. Can any other pins on KC868 AIO be used as GPIO?
KC868-AIO only have 2 free gpio. if you want use more LED strip for WS2812B, you can add another kincony board, such as KinCony S3, there are many free gpio ports can use.
