Full Version: M16 Warning: Component <unknown> took a long time for an operation
I just received my M16 and I flash it with ESPHome. Everything seems to work properly but the logs are flooded by a Warning that I don't know how to solve. I saw a post similar and putting the frequency at 400kHz solved the problem but not for me. Here is a snapshot of thoses warnings:
[09:09:52][W][component:238]: Components should block for at most 30 ms.
[09:09:52][W][component:237]: Component <unknown> took a long time for an operation (53 ms).
[09:09:59][W][component:237]: Component <unknown> took a long time for an operation (52 ms).
[09:09:59][W][component:238]: Components should block for at most 30 ms.
[09:10:07][W][component:237]: Component <unknown> took a long time for an operation (52 ms).
[09:10:07][W][component:238]: Components should block for at most 30 ms.
[09:10:09][W][component:237]: Component <unknown> took a long time for an operation (51 ms).
[09:10:09][W][component:238]: Components should block for at most 30 ms.
[09:10:12][W][component:237]: Component <unknown> took a long time for an operation (51 ms).
[09:10:12][W][component:238]: Components should block for at most 30 ms.
[09:10:17][W][component:237]: Component <unknown> took a long time for an operation (52 ms).
[09:10:17][W][component:238]: Components should block for at most 30 ms.
[09:10:22][W][component:237]: Component <unknown> took a long time for an operation (51 ms).
[09:10:22][W][component:238]: Components should block for at most 30 ms.
[09:10:22][W][component:237]: Component <unknown> took a long time for an operation (54 ms).
[09:10:24][W][component:237]: Component <unknown> took a long time for an operation (51 ms).
[09:10:24][W][component:238]: Components should block for at most 30 ms.
[09:10:29][W][component:237]: Component <unknown> took a long time for an operation (53 ms).
[09:10:29][W][component:238]: Components should block for at most 30 ms.
[09:10:32][W][component:237]: Component <unknown> took a long time for an operation (51 ms).
[09:10:32][W][component:238]: Components should block for at most 30 ms.
[09:10:42][W][component:237]: Component <unknown> took a long time for an operation (54 ms).
[09:10:42][W][component:238]: Components should block for at most 30 ms.
[09:10:44][W][component:237]: Component <unknown> took a long time for an operation (52 ms).
[09:10:44][W][component:238]: Components should block for at most 30 ms.
[09:10:47][W][component:237]: Component <unknown> took a long time for an operation (54 ms).
[09:10:47][W][component:238]: Components should block for at most 30 ms.
[09:10:52][W][component:237]: Component <unknown> took a long time for an operation (51 ms).
[09:10:52][W][component:238]: Components should block for at most 30 ms.
[09:10:54][W][component:237]: Component <unknown> took a long time for an operation (53 ms).
[09:10:54][W][component:238]: Components should block for at most 30 ms.
[09:10:57][W][component:237]: Component <unknown> took a long time for an operation (53 ms).
[09:10:57][W][component:238]: Components should block for at most 30 ms.
[09:11:07][W][component:237]: Component <unknown> took a long time for an operation (53 ms).
[09:11:07][W][component:238]: Components should block for at most 30 ms.
[09:11:12][W][component:237]: Component <unknown> took a long time for an operation (55 ms).
[09:11:12][W][component:238]: Components should block for at most 30 ms.
[09:11:17][W][component:237]: Component <unknown> took a long time for an operation (58 ms).
[09:11:17][W][component:238]: Components should block for at most 30 ms.
[09:11:22][W][component:237]: Component <unknown> took a long time for an operation (51 ms).
[09:11:22][W][component:238]: Components should block for at most 30 ms.
[09:11:24][W][component:237]: Component <unknown> took a long time for an operation (51 ms).
[09:11:24][W][component:238]: Components should block for at most 30 ms.
[09:11:34][W][component:237]: Component <unknown> took a long time for an operation (51 ms).
[09:11:34][W][component:238]: Components should block for at most 30 ms.
do you use M16 or M16v2?
(02-05-2025, 12:32 AM)admin Wrote: [ -> ]do you use M16 or M16v2?
M16v2
If all functions are normal, please ignore it
