Full Version: Etgernet + wifi
Pages: 1 2 3 4
My module (KC868-A) is connected via ethernet and I want it to be an access point via WiFi. How to set up a configuration file in esp home in home assistance ?
(02-06-2025, 01:38 AM)admin Wrote: [ -> ]https://esphome.io/components/captive_portal.html
When I use WiFi and Ethernet at the same time I get an error: Component ethernet cannot be used together with component wifi.
Here is my code
Help me please
  platform: ESP32
wifi:
  ap:
    ssid: "ESP32_garage"
    password: "123456789"
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.199
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  sda: 4
  scl: 5
  - id: 'pcf8574_hub'
# Individual outputs
      pcf8574: pcf8574_hub
      # Use pin number 0
      # One of INPUT or OUTPUT
      inverted: false
When I use WiFi and Ethernet at the same time I get an error. Component ethernet cannot be used together with component wifi.
Here is my code
Help me plaese
  platform: ESP32
wifi:
  ap:
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  phy_addr: 0
  manual_ip:
  sda: 4
  scl: 5
  - id: 'pcf8574_hub'
      # Use pin number 0
      inverted: false
yes, ethernet and wifi can't work at the same time via esphome.
if you MUST want to use ethernet . i suggest you download KCS firmware, so that ethernet and wifi can work at the same time.
(02-06-2025, 07:42 AM)admin Wrote: [ -> ]yes, ethernet and wifi can't work at the same time via esphome.
If I install KCS firmware can I use ESP HOME Home assistants?
if use KCS firmware, let board integrate to home assistant by MQTT, not by ESPHome.
(02-06-2025, 08:45 AM)admin Wrote: [ -> ]if use KCS firmware, let board integrate to home assistant by MQTT, not by ESPHome.
If I install KCS firmware and I don't like it, can I go back?
sure
I installed a new KCS  firmware and want to connect via mqtt . I registered all the settings for mqtt and see the device in the mqtt explorer but I don't see it in mqtt Home Assistants . Check attachment please
Pages: 1 2 3 4
