02-22-2025, 10:43 AM
Dear Kincony team,
It seems to be a problem with the A8S v2 board.
I've tested the A8S v2 with the PoE board and none of the inputs work (using either the KCS or esphome firmware).
If you power the board using the 12v input, everything works as expected (the inputs work), but as soon as you power the board with the Kinkony PoE board, all inputs go down (and they stop showing the expected status).
You can easily diagnose this providing power to the board only with PoE, as you will see the inputs do not work (even using KCS firmware).
I've about 20 A8S v2 boards. How can I correct this so inputs work when using PoE power?
Regards.
Regards.
