04-20-2025, 06:04 AM
* - SCL (clock) on pin IO47
* - SDA (data) on pin IO48
#include <U8g2lib.h> // Include the U8g2 library for controlling the OLED display
#include <Wire.h> // Include the Wire library for I2C communication
// Initialize the display using the software I2C method (SCL = IO47, SDA = IO48)
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0, 47, 48, U8X8_PIN_NONE); // Screen rotation: U8G2_R0
void page1() {
u8g2.setFont(u8g2_font_timR18_tf); // Use the Times Roman font, size 18
u8g2.setFontPosTop(); // Set the text position at the top of the display
u8g2.setCursor(5, 0); // Position the cursor at coordinates (5, 0)
u8g2.print("KINCONY"); // Display the text "KINCONY" on the screen
u8g2.setFont(u8g2_font_timR12_tf); // Use the Times Roman font, size 12
u8g2.setCursor(0, 40); // Position the cursor at coordinates (0, 40)
u8g2.print("www.kincony.com"); // Display the text "www.kincony.com"
u8g2.setI2CAddress(0x3C*2); // I2C address shift for 8-bit format
u8g2.begin();
u8g2.enableUTF8Print(); // Allow UTF-8 encoded text to be printed
u8g2.firstPage(); // Prepare the first page for drawing
do {
page1();
} while (u8g2.nextPage()); // Continue to the next page until all pages are drawn
}[attachment=7468]
[attachment=7469]
