04-20-2025, 06:07 AM
* @brief Example to control relays based on digital input states using ESP32
* @details This program reads the states of two digital inputs (GPIO16, GPIO17)
* and controls two relays (GPIO40, GPIO39) accordingly.
// Define the GPIO pins for digital inputs
#define INPUT1_PIN 16 // GPIO16 for Digital Input 1
#define INPUT2_PIN 17 // GPIO17 for Digital Input 2
// Define the GPIO pins for relays
#define RELAY1_PIN 40 // GPIO40 for Relay 1
#define RELAY2_PIN 39 // GPIO39 for Relay 2
// Initialize the serial communication for debugging
Serial.println("ESP32 Input-Controlled Relay Example");
// Set the input pins as INPUT
pinMode(INPUT1_PIN, INPUT);
pinMode(INPUT2_PIN, INPUT);
// Set the relay pins as OUTPUT
pinMode(RELAY1_PIN, OUTPUT);
pinMode(RELAY2_PIN, OUTPUT);
// Turn off both relays at startup (assuming active LOW relays)
digitalWrite(RELAY1_PIN, HIGH);
digitalWrite(RELAY2_PIN, HIGH);
// Read the state of the digital inputs
int state1 = digitalRead(INPUT1_PIN);
int state2 = digitalRead(INPUT2_PIN);
// Control the relays based on input states
digitalWrite(RELAY1_PIN, state1 == HIGH ? LOW : HIGH); // Activate relay if input is HIGH
digitalWrite(RELAY2_PIN, state2 == HIGH ? LOW : HIGH); // Activate relay if input is HIGH
// Print the states to the Serial Monitor
Serial.print("Digital Input 1 State: ");
Serial.println(state1);
Serial.print("Digital Input 2 State: ");
Serial.println(state2);
// Wait for 100 milliseconds before reading again
delay(100);
}[attachment=7470]
[attachment=7471]
