Full Version: KC868 server firmware
Hello, i like to renew my kc868 server firmware via the serial port.
I try first the method via 10.10.100.254 but the uploading give no result for refactoring my kincony server.
So i go to try the serial methode via cable.
I am wondering if it is ok to use a cable usb-to rs232 with only GND, TX, RX or do i need also other signals like DTR and ....
Please let me now, can you send me the tool to upload the firmware to the server bord via rs232.
Thank you in advance
P. Schippers
you can use 10.10.100.254 , that's wifi module's firmware, NOT KC868-Server ARM CPU firmware.
KC868-Server no new firmware, what firmware version you are using? you can login by ethernet ip to check.
(04-21-2025, 11:25 PM)admin Wrote: [ -> ]you can use 10.10.100.254 , that's wifi module's firmware, NOT KC868-Server ARM CPU firmware.
I i am using V1.48. But i can not login anymore with admin pw admin, tads the reasonĀ  i try to restore the firmware via rs232
i try to reset via 10.10.100.254 with the blue screen update, restore no result.
Please send my kincony tool for upload firmware via cable my email: pierre.schippers15@gmail.com
