Full Version: Problems wifi / ESPHome?
Can somebody test my code my wifi is dropping and cant connect to it after the update esphome
ESPHome Device Builder
Current version: 2025.4.1
Home Assistant
Core 2025.4.4
Supervisor 2025.04.1
Operating System 15.2
Frontend 20250411.0
Network
UniFi OS 4.2.9
Network 9.0.114
do you wifi is 2.4G, not use by 5.8G.
you can use your mobile phone work as wifi hot spot, let your KC868-A128 board connect it for a testing.
I get this error code with fixt lan connection maybe you know where the problem could be I have already looked in the github of HA and EspHome its online in esphome builder and can log
Logger: aioesphomeapi.reconnect_logic
Source: runner.py:154
First occurred: 11:08:35 (5 occurrences)
Last logged: 12:02:26
Can't connect to ESPHome API for koi-rk-kincony-kc868-a128 @ 20.20.20.183: Timeout waiting for HelloResponse, ConnectResponse after 30.0s (TimeoutAPIError)
Can't connect to ESPHome API for koi-rk-kincony-kc868-a128 @ 20.20.20.183: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='20.20.20.183', port=6053))]: [Errno 113] Connect call failed ('20.20.20.183', 6053) (SocketAPIError)
Can't connect to ESPHome API for koi-rk-kincony-kc868-a128 @ 20.20.20.183: koi-rk-kincony-kc868-a128 @ 20.20.20.183: The connection dropped immediately after encrypted hello; Try enabling encryption on the device or turning off encryption on the client (Home Assistant 2025.4.4) (EncryptionHelloAPIError)
Logger: aioesphomeapi.connection
Source: /usr/src/homeassistant/homeassistant/components/esphome/manager.py:382
First occurred: 11:43:51 (5 occurrences)
Last logged: 14:06:47
koi-rk-kincony-kc868-a128 @ 20.20.20.183: disconnect request failed
Traceback (most recent call last):
  File "aioesphomeapi/connection.py", line 820, in aioesphomeapi.connection.APIConnection.send_messages_await_response_complex
TimeoutError
The above exception was the direct cause of the following exception:
  File "aioesphomeapi/connection.py", line 1026, in aioesphomeapi.connection.APIConnection.disconnect
  File "aioesphomeapi/connection.py", line 838, in send_message_await_response
  File "aioesphomeapi/connection.py", line 824, in send_messages_await_response_complex
aioesphomeapi.core.TimeoutAPIError: Timeout waiting for DisconnectResponse after 10.0s
First occurred: 10:54:24 (11 occurrences)
Last logged: 14:13:04
koi-rk-kincony-kc868-a128 @ 20.20.20.183: Connection error occurred: koi-rk-kincony-kc868-a128 @ 20.20.20.183: EOF received
koi-rk-kincony-kc868-a128 @ 20.20.20.183: Connection error occurred: koi-rk-kincony-kc868-a128 @ 20.20.20.183: Connection lost
koi-rk-kincony-kc868-a128 @ 20.20.20.183: Connection error occurred: koi-rk-kincony-kc868-a128 @ 20.20.20.183: The connection dropped immediately after encrypted hello; Try enabling encryption on the device or turning off encryption on the client (Home Assistant 2025.4.4)
do you only want use KC868-A128 board work with digital input and digital output using wifi? if YES, i can test it to compile.
Small update
I also have an A64 board, this board does not have this problem.
Can it be the ESP32 chip that breaks i am going to check the voltage input but it must be fine 24v 25A power supply
also can you test the with wifi
ok, i will test with wifi by esphome.
Tested with KC868-A128. here are two yaml file for ethernet and wifi.
[attachment=7667]
So the esp32 a64 card is stable but the a128 card not can this be a failing esp32
I am going to swap the eth cable
Also i am checking the imput voltage
So update wifi is stable but lan not problem with ethernet chip??
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  #manual_ip:
  #  static_ip: 20.20.20.183
  #  gateway: 20.20.20.1
  #  subnet: 255.255.255.0
  #  dns1: 8.8.8.8
  #  dns2: 1.1.1.1
ethernet not stable?
