05-18-2025, 01:50 PM
Hi!
I've been using the G1 with 4G SIM as a gate opener for a few months now. Some time ago, the G1 stopped registering incoming calls (RING +441234567890 etc not appearing on screen) and the number was not being sent to my MQTT broker. I reflashed with the latest firmware available at the time (3.9.1) and everything started working OK again. The problem has returned. I've reflashed with the latest firmware (3.9.2) but the incoming call isn't being registered on the screen or being sent over MQTT. I can send and receive text messages OK and the 4G online signal is 64%. I can also make a test call from the G1 to my mobile which does cause my phone to ring.
When I first installed the G1, calls to it rang until I cancelled the call. Shortly after, incoming calls were rejected after 1 ring but the SSID was displayed on the screen and passed over MQTT, a better solution for my use case. The incoming calls are still rejected after 1 ring, but the call isn't being registered.
Is there something that I can do to return the incoming call/CallerID functionality?
Thanks,
Bodad
Hi again,
Scratch that. I tried a different SIM and it all worked fine. It must be something about the SIM which is a provider issue, not a G1 issue. However, it would still be helpful to have a setting that allows the number to ring a set number of times (or just until the CallerID is captured) and then rejects the call.
Thanks,
Bodad
Thanks,
Bodad
Hi again,
Thanks,
Bodad
