Full Version: KC868-A128 INPUT toggle OUTPUT ESPhome yaml
[attachment=7739]
[attachment=7740]
  friendly_name: a128
# Example configuration entry
   - id: bus_a
     sda: 5
     scl: 16
     frequency: 400kHz
   - id: bus_b
     sda: 15
     scl: 4
     frequency: 400kHz
   type: LAN8720
   mdc_pin: GPIO23
   mdio_pin: GPIO18
   clk_mode: GPIO17_OUT
   phy_addr: 0
  # Optional manual IP
  # manual_ip:
  #   static_ip: 192.168.1.198
  #   gateway: 192.168.1.1
  #   subnet: 255.255.255.0
    i2c_id: bus_a
    pcf8575: true
  - id: 'pcf8574_hub_out_2'  # for output channel 17-32
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_out_3'  # for output channel 33-48
    i2c_id: bus_a
    address: 0x21
    pcf8575: true
  - id: 'pcf8574_hub_out_4'  # for output channel 49-64
    i2c_id: bus_a
    pcf8575: true
  - id: 'pcf8574_hub_out_5'  # for output channel 65-80
    i2c_id: bus_a
    address: 0x26
    pcf8575: true
  - id: 'pcf8574_hub_out_6'  # for output channel 81-96
    i2c_id: bus_a
    address: 0x27
    pcf8575: true
  - id: 'pcf8574_hub_out_7'  # for output channel 97-112
    i2c_id: bus_a
    address: 0x20
    pcf8575: true
  - id: 'pcf8574_hub_out_8'  # for output channel 113-128
    i2c_id: bus_a
    address: 0x23
    pcf8575: true
  - id: 'pcf8574_hub_in_1'  # for a128-input channel 1-16
    i2c_id: bus_b
    pcf8575: true
  - id: 'pcf8574_hub_in_2'  # for a128-input channel 17-32
    i2c_id: bus_b
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_in_3'  # for a128-input channel 33-48
    i2c_id: bus_b
    address: 0x21
    pcf8575: true
  - id: 'pcf8574_hub_in_4'  # for a128-input channel 49-64
    i2c_id: bus_b
    pcf8575: true
  - id: 'pcf8574_hub_in_5'  # for a128-input channel 65-80
    i2c_id: bus_b
    address: 0x26
    pcf8575: true
  - id: 'pcf8574_hub_in_6'  # for a128-input channel 81-96
    i2c_id: bus_b
    address: 0x27
    pcf8575: true
  - id: 'pcf8574_hub_in_7'  # for a128-input channel 97-112
    i2c_id: bus_b
    address: 0x20
    pcf8575: true
  - id: 'pcf8574_hub_in_8'  # for a128-input channel 113-128
    i2c_id: bus_b
    address: 0x23
    pcf8575: true
# Individual outputs
      pcf8574: pcf8574_hub_out_1
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_2
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_3
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_4
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_5
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_6
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_7
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_8
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
# Individual inputs
    on_press:
      then:
        - switch.toggle: light1
    on_press:
      then:
        - switch.toggle: light2
    on_press:
      then:
        - switch.toggle: light3
    on_press:
      then:
        - switch.toggle: light4
    on_press:
      then:
        - switch.toggle: light5
    on_press:
      then:
        - switch.toggle: light6
    on_press:
      then:
        - switch.toggle: light7
    on_press:
      then:
        - switch.toggle: light8
      number: 8
    on_press:
      then:
        - switch.toggle: light9
      number: 9
    on_press:
      then:
        - switch.toggle: light10
      number: 10
    on_press:
      then:
        - switch.toggle: light11
      number: 11
    on_press:
      then:
        - switch.toggle: light12
      number: 12
    on_press:
      then:
        - switch.toggle: light13
      number: 13
    on_press:
      then:
        - switch.toggle: light14
      number: 14
    on_press:
      then:
        - switch.toggle: light15
      number: 15
    on_press:
      then:
        - switch.toggle: light16
      pcf8574: pcf8574_hub_in_2
    on_press:
      then:
        - switch.toggle: light17
    on_press:
      then:
        - switch.toggle: light18
    on_press:
      then:
        - switch.toggle: light19
    on_press:
      then:
        - switch.toggle: light20
    on_press:
      then:
        - switch.toggle: light21
    on_press:
      then:
        - switch.toggle: light22
    on_press:
      then:
        - switch.toggle: light23
    on_press:
      then:
        - switch.toggle: light24
      number: 8
    on_press:
      then:
        - switch.toggle: light25
      number: 9
    on_press:
      then:
        - switch.toggle: light26
      number: 10
    on_press:
      then:
        - switch.toggle: light27
      number: 11
    on_press:
      then:
        - switch.toggle: light28
      number: 12
    on_press:
      then:
        - switch.toggle: light29
      number: 13
    on_press:
      then:
        - switch.toggle: light30
      number: 14
    on_press:
      then:
        - switch.toggle: light31
      number: 15
    on_press:
      then:
        - switch.toggle: light32
      pcf8574: pcf8574_hub_in_3
    on_press:
      then:
        - switch.toggle: light33
    on_press:
      then:
        - switch.toggle: light34
    on_press:
      then:
        - switch.toggle: light35
    on_press:
      then:
        - switch.toggle: light36
    on_press:
      then:
        - switch.toggle: light37
    on_press:
      then:
        - switch.toggle: light38
    on_press:
      then:
        - switch.toggle: light39
    on_press:
      then:
        - switch.toggle: light40
      number: 8
    on_press:
      then:
        - switch.toggle: light41
      number: 9
    on_press:
      then:
        - switch.toggle: light42
      number: 10
    on_press:
      then:
        - switch.toggle: light43
      number: 11
    on_press:
      then:
        - switch.toggle: light44
      number: 12
    on_press:
      then:
        - switch.toggle: light45
      number: 13
    on_press:
      then:
        - switch.toggle: light46
      number: 14
    on_press:
      then:
        - switch.toggle: light47
      number: 15
    on_press:
      then:
        - switch.toggle: light48
      pcf8574: pcf8574_hub_in_4
    on_press:
      then:
        - switch.toggle: light49
    on_press:
      then:
        - switch.toggle: light50
    on_press:
      then:
        - switch.toggle: light51
    on_press:
      then:
        - switch.toggle: light52
    on_press:
      then:
        - switch.toggle: light53
    on_press:
      then:
        - switch.toggle: light54
    on_press:
      then:
        - switch.toggle: light55
    on_press:
      then:
        - switch.toggle: light56
      number: 8
    on_press:
      then:
        - switch.toggle: light57
      number: 9
    on_press:
      then:
        - switch.toggle: light58
      number: 10
    on_press:
      then:
        - switch.toggle: light59
      number: 11
    on_press:
      then:
        - switch.toggle: light60
      number: 12
    on_press:
      then:
        - switch.toggle: light61
      number: 13
    on_press:
      then:
        - switch.toggle: light62
      number: 14
    on_press:
      then:
        - switch.toggle: light63
      number: 15
    on_press:
      then:
        - switch.toggle: light64
      pcf8574: pcf8574_hub_in_5
    on_press:
      then:
        - switch.toggle: light65
    on_press:
      then:
        - switch.toggle: light66
    on_press:
      then:
        - switch.toggle: light67
    on_press:
      then:
        - switch.toggle: light68
    on_press:
      then:
        - switch.toggle: light69
    on_press:
      then:
        - switch.toggle: light70
    on_press:
      then:
        - switch.toggle: light71
    on_press:
      then:
        - switch.toggle: light72
      number: 8
    on_press:
      then:
        - switch.toggle: light73
      number: 9
    on_press:
      then:
        - switch.toggle: light74
      number: 10
    on_press:
      then:
        - switch.toggle: light75
      number: 11
    on_press:
      then:
        - switch.toggle: light76
      number: 12
    on_press:
      then:
        - switch.toggle: light77
      number: 13
    on_press:
      then:
        - switch.toggle: light78
      number: 14
    on_press:
      then:
        - switch.toggle: light79
      number: 15
    on_press:
      then:
        - switch.toggle: light80
      pcf8574: pcf8574_hub_in_6
    on_press:
      then:
        - switch.toggle: light81
    on_press:
      then:
        - switch.toggle: light82
    on_press:
      then:
        - switch.toggle: light83
    on_press:
      then:
        - switch.toggle: light84
    on_press:
      then:
        - switch.toggle: light85
    on_press:
      then:
        - switch.toggle: light86
    on_press:
      then:
        - switch.toggle: light87
    on_press:
      then:
        - switch.toggle: light88
      number: 8
    on_press:
      then:
        - switch.toggle: light89
      number: 9
    on_press:
      then:
        - switch.toggle: light90
      number: 10
    on_press:
      then:
        - switch.toggle: light91
      number: 11
    on_press:
      then:
        - switch.toggle: light92
      number: 12
    on_press:
      then:
        - switch.toggle: light93
      number: 13
    on_press:
      then:
        - switch.toggle: light94
      number: 14
    on_press:
      then:
        - switch.toggle: light95
      number: 15
    on_press:
      then:
        - switch.toggle: light96
      pcf8574: pcf8574_hub_in_7
    on_press:
      then:
        - switch.toggle: light97
    on_press:
      then:
        - switch.toggle: light98
    on_press:
      then:
        - switch.toggle: light99
    on_press:
      then:
        - switch.toggle: light100
    on_press:
      then:
        - switch.toggle: light101
    on_press:
      then:
        - switch.toggle: light102
    on_press:
      then:
        - switch.toggle: light103
    on_press:
      then:
        - switch.toggle: light104
      number: 8
    on_press:
      then:
        - switch.toggle: light105
      number: 9
    on_press:
      then:
        - switch.toggle: light106
      number: 10
    on_press:
      then:
        - switch.toggle: light107
      number: 11
    on_press:
      then:
        - switch.toggle: light108
      number: 12
    on_press:
      then:
        - switch.toggle: light109
      number: 13
    on_press:
      then:
        - switch.toggle: light110
      number: 14
    on_press:
      then:
        - switch.toggle: light111
      number: 15
    on_press:
      then:
        - switch.toggle: light112
      pcf8574: pcf8574_hub_in_8
    on_press:
      then:
        - switch.toggle: light113
    on_press:
      then:
        - switch.toggle: light114
    on_press:
      then:
        - switch.toggle: light115
    on_press:
      then:
        - switch.toggle: light116
    on_press:
      then:
        - switch.toggle: light117
    on_press:
      then:
        - switch.toggle: light118
    on_press:
      then:
        - switch.toggle: light119
    on_press:
      then:
        - switch.toggle: light120
      number: 8
    on_press:
      then:
        - switch.toggle: light121
      number: 9
    on_press:
      then:
        - switch.toggle: light122
      number: 10
    on_press:
      then:
        - switch.toggle: light123
      number: 11
    on_press:
      then:
        - switch.toggle: light124
      number: 12
    on_press:
      then:
        - switch.toggle: light125
      number: 13
    on_press:
      then:
        - switch.toggle: light126
      number: 14
    on_press:
      then:
        - switch.toggle: light127
      number: 15
    on_press:
      then:
        - switch.toggle: light128
web_server:
  port: 80
yaml file download:
[attachment=7741]
firmware BIN file download (download at 0x0 address , directly to use):
[attachment=7742]
after download firmware, ethernet will work as DHCP mode. find the IP address from your router, then use IP address login by web browser.
