[attachment=308][attachment=309][attachment=309][attachment=308][attachment=309][attachment=310][attachment=311][attachment=312]Unable to Connect using the Application KC868-H32BS Either using any of the two apps ( KBOX- SMART HOME )
[attachment=313 Wrote:engrezk pid='1705' dateline='1632924829']Unable to Connect using the Application KC868-H32BS Either using any of the two apps ( KBOX- SMART HOME )
By the looks of it youre ip nets are totally wrong. You are trying to connect to a ip net while being in a complete different ip range. I guess you should change one of the 2 to the right ip net range. I am quite sure you can solve the problem this way.
Greetings from Germany
1. what's your rouer's IP address?
2. set work mode="UDP" work for "kincony smart home app" , i seen your phone screen, controller is online, you need to add controller for a roon begin to use. here is video tour:
https://www.youtube.com/watch?v=FyPVUguU...x=3&t=237s
3. set work mode="TCP Server" work for "KBOX", but when you using "KBOX", it's use for local network, so your mobile phone need to use wifi connect to your router. i seen your screen is use by 4G.
4. any questions you can leave message, or you can add whatsapp number: +86-13336170682 we use teamviewer remote help you.
(09-30-2021, 12:09 AM)admin Wrote: [ -> ]1. what's your rouer's IP address?
2. set work mode="UDP" work for "kincony smart home app" , i seen your phone screen, controller is online, you need to add controller for a roon begin to use. here is video tour: https://www.youtube.com/watch?v=FyPVUguU...x=3&t=237s
Sent to you on WhatsApp. Please check WhatsApp
