hello sir
i want to install home assistant using LAN connector but when i type
http://homeassistant:8123/ nothing happen
my ethernet already connected but still unidentified network
can someone help me?
attachment=7947]
your server16 and your computer connect to same router. not use ethernet cable connect to your computer directly.
(07-04-2025, 05:39 AM)admin Wrote: [ -> ]your server16 and your computer connect to same router. not use ethernet cable connect to your computer directly.
and how long i must reload the page ?
I remove this, does it have any effect?
do you have used pi image tool downloaded home assistant firmware?
after download home assistant, login by your router, check your server16's ip. then use
http://ip:8123 to login, not use by domain name.
(07-07-2025, 10:49 PM)admin Wrote: [ -> ]after download home assistant, login by your router, check your server16's ip. then use http://ip:8123 to login, not use by domain name.
took too long to respond.
refused to connect.
the connection server 16 isnt stable, i check ping from cmd and waiting 10 minutes always DHU, connect and then RTO.
we already have re send you a new server16, you can test with new one.
(07-22-2025, 06:44 AM)admin Wrote: [ -> ]we already have re send you a new server16, you can test with new one.
i need this tool for my project, if i send it there it will take a lot of time because i am in indonesia.
what is damaged according to your analysis from what i report?
my lecturer asked if it is possible to send a replacement tool first and then i send my tool?
if possible, what should i send, one package or just the tool?
