Full Version: Multichannel Omron Relay Module - flyback diode
I noticed the "Multichannel Omron Relay Module" item on your store (https://www.aliexpress.com/item/1005003084693879.html). I have some questions about it: (1) Does it have flyback diodes per channel? (2) Where are the capacitors schematically connected to?
Thanks, Elad.
1: flyback diodes per channel already have installed on H32BS' every output channel. Omron Relay Module have design the part for diodes, but not weld, if you want, can weld it on PCB.
2: no capacitors on Omron relay module, not need use capacitors.
Thanks!
