Full Version: AIO Hybrid ESPHome yaml for home assistant without tuya
  friendly_name: AIO-hybrid
  platformio_options:
    board_build.flash_mode: dio
  board: esp32-s3-devkitc-1
    type: esp-idf
    sdkconfig_options:
      SOC_RMT_SUPPORT_RX_PINGPONG: "n"
  - id: uart_zsu
    baud_rate: 115200
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
      sequence:
        - lambda: UARTDebug::log_string(direction, bytes);
    tx_pin: 15
    rx_pin: 48
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
  - id: 'pcf8574_hub_output_1'  # for output channel 5
    i2c_id: bus_a
    address: 0x26
  - id: 'pcf8574_hub_input_1'  # for input channel 1-12
    i2c_id: bus_a
    pcf8575: true
  - platform: uart
    uart_id: uart_zsu
    data: [0x55, 0xaa, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x01, 0x00, 0x04] # ZSU zigbee module
      pcf8574: pcf8574_hub_output_1
  - platform: template
    turn_on_action:
      - remote_transmitter.transmit_pronto:
          transmitter_id: ir1
          data: "0000 006C 0022 0002 015B 00AD 0016 0041 0016 0016 0016 0041 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0041 0016 0575 015B 0057 0016 0E6C"
      pcf8574: pcf8574_hub_input_1
      number: 8
      number: 9
      number: 10
      number: 11
## without resistance on PCB
      number: 40
      inverted:  false
      inverted:  false
mcp4728:
  - id: dac_output
output:
- platform: mcp4728
  mcp4728_id: dac_output
  channel: A
  vref: vdd
  power_down: normal # default
- platform: mcp4728
  channel: B
  vref: vdd
- platform: mcp4728
  channel: C
  vref: vdd
- platform: mcp4728
  channel: D
  vref: vdd
light:
  - platform: monochromatic
    output: dimmer1
    gamma_correct: 1.0
    output: dimmer2
    gamma_correct: 1.0
    output: dimmer3
    gamma_correct: 1.0
    output: dimmer4
    gamma_correct: 1.0
    rgb_order: GRB
    pin: GPIO21
    num_leds: 20
    chipset: ws2812
    name: "My Light IO21"
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "AIO-hybrid");
  - platform: adc
    pin: 5
    name: "AIO_hybrid A1 Voltage"
    update_interval: 55s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 7
    name: "AIO_hybrid A2 Voltage"
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 6
    name: "AIO_hybrid A3 Current"
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 4
    name: "AIO_hybrid A4 Current"
    attenuation: 11db
    filters:
remote_receiver:
  pin: 17
  dump: all
remote_transmitter:
  - id: ir1
    pin: 14
    carrier_duty_percent: 50%
web_server:
  port: 80
download yaml file:
[attachment=8322]
