09-15-2025, 01:24 AM
* PCF8574 Relay Control Example
* Controls 5 relays connected to PCF8574 via I2C bus.
* Made By KinCony
* https://www.kincony.com
#include <Arduino.h>
#include <Wire.h>
#include "PCF8574.h"
// I2C pin definitions
#define I2C_SDA 8
#define I2C_SCL 18
// Create PCF8574 object with I2C address 0x26
PCF8574 pcf8574(0x26);
delay(500);
// Initialize I2C with specified SDA and SCL pins
Wire.begin(I2C_SDA, I2C_SCL);
// Set PCF8574 P3~P7 as OUTPUT (Relays)
pcf8574.pinMode(P3, OUTPUT);
pcf8574.pinMode(P4, OUTPUT);
pcf8574.pinMode(P5, OUTPUT);
pcf8574.pinMode(P6, OUTPUT);
pcf8574.pinMode(P7, OUTPUT);
if (pcf8574.begin()) {
Serial.println("OK");
Serial.println("KO");
while (1); // Stop if initialization fails
// Turn OFF all relays at startup
for (int pin = P3; pin <= P7; pin++) {
pcf8574.digitalWrite(pin, LOW);
// Turn ON all relays one by one
pcf8574.digitalWrite(pin, HIGH);
delay(500);
delay(1000); // Keep all relays ON for a while
delay(1000); // Keep all relays OFF for a while
}[attachment=8323]
[attachment=8324]
