attachment=337]
dear admin
I need some help. please explain how do you place a "AND" statement "OR" statement in the Kincony Controller Application as attached?
My example would be:-
1. Run the pump (Relay 32) for 2min AND if Water Float is empty shutoff pump (Relay 32)
I can find the "AND" statement "OR" statement on the application.
Thank you
Regards
Subas
IF command list all is "AND" logical. if you add IF command list for A , B, C. that means A and B and C
if you create two IFTTT command, that is "OR", such as you create IFTTT command number-1 and number-2. number-1 and number-2 IFTTT command is "OR" logical.
(10-18-2021, 11:32 AM)admin Wrote: [ -> ]IF command list all is "AND" logical. if you add IF command list for A , B, C. that means A and B and C
Dear Admin.
Thank you for the answers.
Do you have a YouTube video on these "AND" / "OR" commands?
Regards
now not have this video , if you want, we can make a video tour.
(10-19-2021, 10:05 AM)admin Wrote: [ -> ]now not have this video , if you want, we can make a video tour.
Dear Admin.
If you can make a very short video showing a Temperature sensor and a Digital In will be perfect.
For example,
a) IF Temp is above 30deg C "AND" Digital Input (DI) is a "1" then Relay32 "OPEN"
b) IF Temp is above 30deg C "OR" Digital Input (DI) is a "1" then Relay31 "OPEN"
Regards
now the DI is judge by rising level or falling level means trigger.
such as :a) IF Temp is above 30deg C "AND" Digital Input (DI) is ↑ THEN trigger. whether OK?
b) IF Temp is above 30deg C "OR" Digital Input (DI) is a ↑ then Relay31 "OPEN" whether OK?
