Full Version: RS485 Modbus SHT30 sensor setting
I have RS485 SHT30 sensors like below.
How should I configure and wire it to use as sensor in KCS v3?
Should I use rs485 TR/TS option? This is not a Kincony sensor.
[Image: WDQahWs.png]
[Image: 0P0Dk8d.png]
TS option only work with kincony TS product, different product have different protocols.
Thank You. I’d like to suggest:
Option 1 – Custom sensor support:
Allow users to manually define Slave address, register number, function code and value multiplier in the Sensors section - so any standard SHT30 RS485 sensor works natively as Sensor.
Option 2 – Protocol documentation:
Publish the KinCony TS Modbus register map so users can reprogram third-party sensors to match the TS protocol.
Modbus Pull (v3.24.2):
Can the new “standard Modbus RTU V2 protocol handler” read data from a third-party RS485 sensor and publish it via MQTT to Home Assistant automatically?
I think many users have third-party RS485 sensors - this would be a very useful addition.
Thank you!
thanks for your suggestion. in future KCS v3 firmware will do this.
here is KinCony TS sensor modbus protocol register: https://www.kincony.com/forum/showthread.php?tid=9185
this week will release new firmware support add modbus sensor. here is sensor setting screen.
[attachment=9798]
Как изменить настройки SHT30 RS-485 в меню F24?
(05-11-2026, 02:30 AM)admin Wrote: [ -> ]this week will release new firmware support add modbus sensor. here is sensor setting screen.
This is huge!
Thanks a lot Smile
you can download newest KCS v3 firmware, already support modbus sensor now.
