I see that the 4 channels unit has only one 1wire port.
Can you connect several 1wire chips on the same port ( the 1 wire standard protocol)?
Then can you collect with MQTT the temperature(s) from this 1 wire port?
Thank you
I see that the 4 channels unit has only one 1wire port. what's your means? which prodocut model you are talking?
if you can write arduino code, you can read 1-wire device for MQTT feedback. Yes , 1-wire port support use by multi sensor, such as multi DS18B20. just according to your arduino code.
