Full Version: Questions on the B4M
I have a bunch of questions about the B4M that I don't see in any of the docs:
What is rated DC V and A range for the MOSFET relays?  I'd like to use it for 5-24V, no more than 2A.
Can the B8M relays can handle mixed voltages/references? Like 12V on one relay and 24V on a different one?
What wire gauge size range do the relay terminals accept?
What is the power supply rating (V, A) in the B4M bundle B power supply?
With the KDS v3 firmware: does the B4M will present its relays over the network to Home Assistant (via auto discovery)?
If I connect several DS18B20 temperature sensors to the B4M one wire interfaces will these be automatically presented to Home Assistant as temp sensors across the network or will have to code the Home Assistant presentation and auto-discovery on the B4M?
Thanks for any help.
1: mosfet use by DC 12-24v load. <2A is ok.
2: NO, only work with one voltage. 12v or 24v.
3: you are asking B8M or B4M ? it's mosfet output, no relay on PCB.
4: DC12v 2A power supply.
5: B4M support mqtt auto discovery for home assistant.
6: multi DS18B20 sensors also will auto discovery by home assistant using KCS v3 firmware.
I downloaded and flashed the KCS_B4M_V3.23.2 bin to my device but the flash tool was set to use address 0x1 instead of 0x0. Now the device wil no longer connect via usb. How can I recover from this?
eraser ESP32S3, re download to address 0x0
