08-30-2026, 11:47 PM
[attachment=10328]
esphome yaml file download:
[attachment=10329]
friendly_name: KinCony CO16
name_add_mac_suffix: true
min_version: 2026.5.3
variant: esp32s3
flash_size: 16MB
type: esp-idf
sdkconfig_options:
CONFIG_ESP32S3_DEFAULT_CPU_FREQ_240: y
CONFIG_ESP32S3_DATA_CACHE_64KB: y
CONFIG_ESP32S3_DATA_CACHE_LINE_64B: y
CONFIG_SPIRAM_FETCH_INSTRUCTIONS: y
CONFIG_SPIRAM_RODATA: y
psram:
mode: octal
speed: 80MHz
ota:
- platform: esphome
# ESPHome does not support Ethernet and Wi-Fi at the same time. Remove this
# block before adding a wifi: configuration.
type: W5500
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
interrupt_pin: GPIO43
reset_pin: GPIO44
clock_speed: 16MHz
interface: spi2
web_server:
port: 80
external_components:
- source:
type: git
url: https://github.com/hzkincony/esphome-nx3l4051
ref: c3b3d5fe6a23e43875dab20dce9ee517a67e95a1
components:
- nx3l4051
- nx3l4051_max31865
sda: GPIO8
scl: GPIO18
frequency: 100kHz
- id: co16_relay_hub
pcf8575: true
xl9535:
- id: co16_input_hub
ads1115:
- id: co16_adc_01_04
address: 0x48
- id: co16_adc_05_08
address: 0x49
- id: co16_adc_09_12
address: 0x4B
- id: co16_adc_13_16
address: 0x4A
nx3l4051:
- id: co16_pt100_mux
pin_s1: GPIO7
pin_s2: GPIO21
pin_s3: LOW
delay: 20ms
globals:
- id: co16_pt100_channel
type: uint8_t
restore_value: false
initial_value: "0"
name: "CO16 Output 01"
restore_mode: ALWAYS_OFF
pcf8574: co16_relay_hub
name: "CO16 Output 02"
name: "CO16 Output 03"
name: "CO16 Output 04"
name: "CO16 Output 05"
name: "CO16 Output 06"
name: "CO16 Output 07"
name: "CO16 Output 08"
name: "CO16 Output 09"
number: 8
name: "CO16 Output 10"
number: 9
name: "CO16 Output 11"
number: 10
name: "CO16 Output 12"
number: 11
name: "CO16 Output 13"
number: 12
name: "CO16 Output 14"
number: 13
name: "CO16 Output 15"
number: 14
name: "CO16 Output 16"
number: 15
name: "CO16 Input 01"
xl9535: co16_input_hub
name: "CO16 Input 02"
name: "CO16 Input 03"
name: "CO16 Input 04"
name: "CO16 Input 05"
name: "CO16 Input 06"
name: "CO16 Input 07"
name: "CO16 Input 08"
name: "CO16 Input 09"
number: 10
name: "CO16 Input 10"
number: 11
name: "CO16 Input 11"
number: 12
name: "CO16 Input 12"
number: 13
name: "CO16 Input 13"
number: 14
name: "CO16 Input 14"
number: 15
name: "CO16 Input 15"
number: 16
name: "CO16 Input 16"
number: 17
# The default filters expose the terminal measurements as 0-10 V.
# For a 4-20 mA channel, replace its filters with: [{multiply: 10.0}]
# and change the unit/device class to mA/current.
- platform: ads1115
ads1115_id: co16_adc_01_04
multiplexer: A0_GND
gain: 4.096
name: "CO16 Analog Input 01"
unit_of_measurement: V
device_class: voltage
state_class: measurement
accuracy_decimals: 2
update_interval: 5s
filters:
- lambda: 'return x <= 0.0025f ? 0.0f : x;'
- multiply: 5.16696
- clamp:
min_value: 0.0
max_value: 10.0
- platform: ads1115
multiplexer: A1_GND
gain: 4.096
name: "CO16 Analog Input 02"
update_interval: 5s
filters:
- multiply: 5.16696
- clamp:
min_value: 0.0
max_value: 10.0
- platform: ads1115
multiplexer: A2_GND
gain: 4.096
name: "CO16 Analog Input 03"
update_interval: 5s
filters:
- multiply: 5.16696
- clamp:
min_value: 0.0
max_value: 10.0
- platform: ads1115
multiplexer: A3_GND
gain: 4.096
name: "CO16 Analog Input 04"
update_interval: 5s
filters:
- multiply: 5.16696
- clamp:
min_value: 0.0
max_value: 10.0
- platform: ads1115
ads1115_id: co16_adc_05_08
multiplexer: A0_GND
gain: 4.096
name: "CO16 Analog Input 05"
update_interval: 5s
filters:
- multiply: 5.16696
- clamp:
min_value: 0.0
max_value: 10.0
- platform: ads1115
multiplexer: A1_GND
gain: 4.096
name: "CO16 Analog Input 06"
update_interval: 5s
filters:
- multiply: 5.16696
- clamp:
min_value: 0.0
max_value: 10.0
- platform: ads1115
multiplexer: A2_GND
gain: 4.096
name: "CO16 Analog Input 07"
update_interval: 5s
filters:
- multiply: 5.16696
- clamp:
min_value: 0.0
max_value: 10.0
- platform: ads1115
multiplexer: A3_GND
gain: 4.096
name: "CO16 Analog Input 08"
update_interval: 5s
filters:
- multiply: 5.16696
- clamp:
min_value: 0.0
max_value: 10.0
- platform: ads1115
ads1115_id: co16_adc_09_12
multiplexer: A0_GND
gain: 4.096
name: "CO16 Analog Input 09"
update_interval: 5s
filters:
- multiply: 5.16696
- clamp:
min_value: 0.0
max_value: 10.0
- platform: ads1115
multiplexer: A1_GND
gain: 4.096
name: "CO16 Analog Input 10"
update_interval: 5s
filters:
- multiply: 5.16696
- clamp:
min_value: 0.0
max_value: 10.0
- platform: ads1115
multiplexer: A2_GND
gain: 4.096
name: "CO16 Analog Input 11"
update_interval: 5s
filters:
- multiply: 5.16696
- clamp:
min_value: 0.0
max_value: 10.0
- platform: ads1115
multiplexer: A3_GND
gain: 4.096
name: "CO16 Analog Input 12"
update_interval: 5s
filters:
- multiply: 5.16696
- clamp:
min_value: 0.0
max_value: 10.0
- platform: ads1115
ads1115_id: co16_adc_13_16
multiplexer: A0_GND
gain: 4.096
name: "CO16 Analog Input 13"
update_interval: 5s
filters:
- multiply: 5.16696
- clamp:
min_value: 0.0
max_value: 10.0
- platform: ads1115
multiplexer: A1_GND
gain: 4.096
name: "CO16 Analog Input 14"
update_interval: 5s
filters:
- multiply: 5.16696
- clamp:
min_value: 0.0
max_value: 10.0
- platform: ads1115
multiplexer: A2_GND
gain: 4.096
name: "CO16 Analog Input 15"
update_interval: 5s
filters:
- multiply: 5.16696
- clamp:
min_value: 0.0
max_value: 10.0
- platform: ads1115
multiplexer: A3_GND
gain: 4.096
name: "CO16 Analog Input 16"
update_interval: 5s
filters:
- multiply: 5.16696
- clamp:
min_value: 0.0
max_value: 10.0
- platform: nx3l4051_max31865
mux_id: co16_pt100_mux
internal: true
clk_pin: GPIO11
mosi_pin: GPIO10
miso_pin: GPIO12
cs_pin: GPIO14
reference_resistance: 400 ohm
rtd_nominal_resistance: 100 ohm
rtd_wires: 3
mains_filter: 50 Hz
update_interval: never
- platform: template
name: "CO16 PT100 01"
unit_of_measurement: "°C"
device_class: temperature
name: "CO16 PT100 02"
name: "CO16 PT100 03"
name: "CO16 PT100 04"
interval:
- interval: 10s
then:
- repeat:
count: 4
then:
- nx3l4051.select:
channel: !lambda return id(co16_pt100_channel);
- component.update: co16_pt100_reader
- delay: 70ms
- lambda: |-
const float value = id(co16_pt100_reader).state;
switch (id(co16_pt100_channel)) {
case 0:
id(co16_pt100_01).publish_state(value);
break;
case 1:
id(co16_pt100_02).publish_state(value);
break;
case 2:
id(co16_pt100_03).publish_state(value);
break;
default:
id(co16_pt100_04).publish_state(value);
break;
id(co16_pt100_channel) = (id(co16_pt100_channel) + 1) % 4;[attachment=10329]
