Full Version: No ethernet communication
Hi, I just received a new  board. I cant accees it through ethernet. I guess the kcs comes with dhcp enabled. if yes, I cant see it with a scanner, I cant find it with the kincony scan tool. I reflashed with esp home and the A8 yaml file, no way. I reflash with the kincony flashing tool and kscv3, no way. The port I am using on the switch is fine, thats the one I am using for my PC . By the way, the board is V1.7.1, I is it the new board? I hope so, I just got it, expecting to use it with 1wire sensors expecting the kcs v3 to solve my 1wire instable sensors issue.
 [attachment=10358]
take a photo of your pcb.
the picture
picture, did you get it?
you need download KCS v2 firmware by usb-c cable firstly.
here is KCS v2 online guide: https://www.kincony.com/esp32-kcsv2-firmware.html
Is it an old module? cant use v3? where is kcsV2?
error
just downloaded the kcs v2.20 from your site
ok flash is ok with your tool, but do not work with the esp one. Please tell me if this board can resceive V3. I need a board for 1wire sensors, the site says v3 solve the stability pbs of the sensors.
The flashing process does not stop, its stayed on sync and the page is filled with dots, and goes on, goes on. First time I have so many pbs with my 5 kincony boards.
Frustrated with that, and by not having received a board that can hold V3
Question, all oy my board are kcs v2. To get my 3m long 1wire sensor to work correctly, should I flash with esphome and another firmware? or should I move to another hardware
KCS v3 use for KC868-A8v3 board, that made by ESP32S3.
I ordered a board 3 weeks ago, why did i receive an old one? I need to get a better solution for 1 wire sensors, if you say that kcs 2 must be replaced with V3 and you produce a new board replacing the 1,7,1, why am I receiving an old one, without warning?? Not happy at all for all this time lost
So far I was having dingtian boardnand kincony . Kincony as I was having to get 1 wire stuff. If it does not wiork for my 4 previous K A8 boards, plus this new one I received, why should I pay more than a dingtian 8 channels if the 1 wire is of no use ?????
https://www.kincony.com/forum/showthread...ight=1wire
You acknowledge that kcs 2 cannot support more than 1 sensor. Why that is not fully stated in your litterarture?. Very frustrated to discover that nafter I install 5 A8 boards. If I have to desinstall all of them and bring them back next to my pc to reinstall with esphome!!!!  nGive me a simple and quick solution. Swap them with the new one that does what your litterature is saying " support of 2 1 wire sensors"
KC868-A8 and KC868-A8v3 are two different product, different price. where you bought from? send us your order number, we will check.
here it is. You have 5 or 6 products pages ( so 12s of products. How do you want me who bought several A8 can discover that there is a new A8 board that should od the multiple 1 wire sensors. Your vendor is not carrying the board you mention.
How do I connect my A8 to 2 1wire sensors. I tried esphome to flash my A8 spare without success.
