COL - start index error - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: COL - start index error (/showthread.php?tid=1216) Pages:
1
2
RE: COL - start index error - admin - 12-20-2021 this is col pc software in my pc with 1920*1080. where have problem with your window? RE: COL - start index error - athxp - 12-20-2021 my monitor is set in full hd, 1920x1080. however the "kincony sbc" screen is poorly proportioned. in red I have highlighted the side that needs to be moved to have a complete view. from the settings I have: 1230x740 and even if I change them to 1920x1080 they immediately return to the previous value. I can't get a screen like yours. RE: COL - start index error - admin - 12-21-2021 maybe you can change this setting. i am using PC monitor, do you use tablet? or PC monitor? RE: COL - start index error - athxp - 12-21-2021 use 40" monitor, recommended is 150% RE: COL - start index error - admin - 12-21-2021 my means, change the recommended to 100% for a test. RE: COL - start index error - athxp - 12-21-2021 I tried, it improves the app but the windows screen remains too small (icons, writings etc. etc.). the value contained in the "cfg.ini" file changes. with a 40 ", however, I cannot keep the scale at 100%. |
