KC868-D16 + Relay SSR (Voltage Regulator) - Printable Version
+--- Thread: KC868-D16 + Relay SSR (Voltage Regulator) (/showthread.php?tid=3759)
Pages: 1 2
RE: KC868-D16 + Relay SSR (Voltage Regulator) - ale_ - 02-06-2024
(02-06-2024, 12:37 AM)admin Wrote: if you use "tungsten wire type" light bulb, not MUST >18W. you can add whatsapp number:  +86-15381188302  i can send you a video D16 work with SSR and bulb.
also we are designing new dimmer board, here is video tour: https://youtube.com/shorts/LANReKNJuM8
In fact it is not needed for old style light bulbs. But im talking about led here, its much more common to have for example 2 led light (7w) bulbs connected in series that generate 14w load.
What im thinking is to put some kind of resistor in the ssr output (kind of bleeder resistor), so I ensure to always have > 18w of load, my doubt is how to the math to buy the resistor...
There are several on Aliexpress, can you help me to choose ?
https://pt.aliexpress.com/item/1005002991919424.html?spm=a2g0o.productlist.main.9.60fd2a6aOLZlrd&algo_pvid=7bb1a3b7-461c-4962-aba5-dda77cad9bf3&aem_p4p_detail=202402051747132640249936671880000730166&algo_exp_id=7bb1a3b7-461c-4962-aba5-dda77cad9bf3-4&pdp_npi=4%40dis%21BRL%2144.89%2122.45%21%21%218.60%214.30%21%402101efac17071840332041905e287f%2112000023106308638%21sea%21BR%21899118599%21&curPageLogUid=BKdY7CkXWF9e&utparam-url=scene%3Asearch%7Cquery_from%3A&search_p4p_id=202402051747132640249936671880000730166_1
RE: KC868-D16 + Relay SSR (Voltage Regulator) - admin - 02-06-2024
You can test without resistance first, which requires practice to verify. In theory, it is useless.
