Learn the remoter of E8T - Printable Version
+--- Forum: KC868-E8T (https://www.kincony.com/forum/forumdisplay.php?fid=36)
+--- Thread: Learn the remoter of E8T (/showthread.php?tid=3103)
Pages: 1 2 3
RE: Learn the remoter of E8T - Alpha21 - 08-20-2023
(08-17-2023, 02:10 PM)admin Wrote: make sure your tuya library  config file
#define WIFI_CONTROL_SELF_MODE  0
please check this., same error., considering it is a default code from your side
RE: Learn the remoter of E8T - admin - 08-21-2023
when i have free time, make a new firmware for you. learn RF button for ALL ON and ALL OFF function.
RE: Learn the remoter of E8T - Alpha21 - 08-21-2023
(08-21-2023, 02:23 AM)admin Wrote: when i have free time, make a new firmware for you. learn RF button for ALL ON and ALL OFF function.
yes please were trying to modify it but the problem is that the default source code have some error., were planning to finish it within this week., hope you can help us with this. Thanks in advance
RE: Learn the remoter of E8T - admin - 08-22-2023
firmware update at here:
https://www.kincony.com/forum/showthread.php?tid=3185
RE: Learn the remoter of E8T - sarah-23652 - 09-21-2023
(07-25-2023, 08:35 AM)Alpha21 Wrote: Good Day! I would like to use one RF  button for turning ON and turning  OFF all the relays of KC868-E8T. Same with the functionality in tuya where there is ALL ON and ALL OFF button.
Since the roofing mclean va remote contain 16 Buttons. Hoping for your response
Hello dear, To Control All relays on your KC868-E8T with RF Button program the button to sand a unique single and configure your KC868-E8T reggaes it. Then set up action in both All One  and All Of in the KC868-E8T setting and test the set up.
RE: Learn the remoter of E8T - raywohlfarth - 10-21-2023
Since the roofing remote contain 16 Buttons.  more guide a https://restonroof.com/oakton-va.php hoping for your response..
RE: Learn the remoter of E8T - sarhaii - 11-02-2023
Our highly experienced roofing contractors only use professional-grade materials. We provide you with FREE comprehensive inspection to ensure your roof remains in peak condition throughout the year.
Our residential and commercial roofing Arlington va contractors can do it all?
RE: Learn the remoter of E8T - sarah-23652 - 12-27-2023
My EPDM roof must have a big section cut out to repair water damage (a leak around ac that only showed up recently, must have leaked for some time). I am looking for suggestions as to what liquid roof product to use to do the entire roof over the existing rubber roof as well as the exposed plywood from the repair. I’m leaning toward a system called https://restonroof.com/burke-va.php but would love to find what others have used with success.
RE: Learn the remoter of E8T - sarah-23652 - 02-06-2024
(08-22-2023, 06:47 AM)admin Wrote: firmware update at here:
roof repair reston va
