KC868-Server home automation local server released! - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: News (https://www.kincony.com/forum/forumdisplay.php?fid=5) +--- Thread: KC868-Server home automation local server released! (/showthread.php?tid=1720) |
KC868-Server home automation local server released! - admin - 02-28-2022 We have successfully developed the most innovative product — KC868-Server. KC868-Server is a super smart controller for smart home automation and industrial automation control. KC868-Server smart controller support MOSFET output and wall switch connect to it directly. Also have analog input and digital input ports. The most important is integrated Raspberry pi CM4 module. Also integrated ESP32 module for you to write your own code. It’s very powerful and flexible. a. Support different work mode: UDP (connect with KinCony’s Cloud server) TCP Server (controller work as a server) TCP Client (controller connect to any user’s server) MQTT (connect to any MQTT broker server) b. Output auto recovery when power failure c. every channel output can set momentary time independently (1—10000 seconds) d. user can define “double click” action for every switch buttons. e. input sensor filter time can set 10ms—1 second. f. 16 switch buttons support multi-click MQTT message feedback.
