Issues with software - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: Issues with software (/showthread.php?tid=283) |
Issues with software - Eugene - 06-01-2021 Hello everyone! We are using KC868-H32 via Ethernet connection and have problems with PC app: 1. We cannot check the connection status while the application is running. So after the first successful connection, we don't know the current status. If something goes wrong, we will not know about it. 2. If there is no connection between the PC and the relay module, we can still turn the relays on and off in the app, but the relays will not switch in reality! And if we do this remotely, it is very difficult or impossible to check if the relays are actually switching. Dear Kincony Team, what should we do? Maybe you have a new version of the app? Thanks in advance! RE: Issues with software - admin - 06-01-2021 suggest use new version PC software: https://www.kincony.com/download/MulitiBoardCtrlV1.0.3.0324.zip This is use in local LAN. RE: Issues with software - Eugene - 06-01-2021 (06-01-2021, 11:01 AM)admin Wrote: suggest use new version PC software: https://www.kincony.com/download/MulitiBoardCtrlV1.0.3.0324.zip This is use in local LAN. Great! It seems to work. A lot of thanks! But I see only relays. And what about input connectors? RE: Issues with software - admin - 06-01-2021 this mainly for output with relay board, support multi board use, the new software design input state monitor for COL/COLB. |
