Double/long click - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: Double/long click (/showthread.php?tid=307) Pages:
1
2
RE: Double/long click - athxp - 09-13-2021 will there be any update for h32L? RE: Double/long click - admin - 09-13-2021 H32L not enough memory for firmware update. B series controller use large memory CPU. RE: Double/long click - Sten - 09-13-2021 Hi This is very good news, but please don't forget your existing customers. I hope you will make the software update for KC868-32B Thank You Sten RE: Double/long click - admin - 09-14-2021 because H32BS have integrated "switch terminal board" , so it can double click function can easy set by webpage. if you are using H32L or H32B, add the raspberry PI running Node-Red can work with double click function by switch panel or zigbee switch panel. RE: Double/long click - xray - 11-02-2022 Is the H32B supporting double click and if yes, how? Do you have some details , knowledge base article or video tutorial? RE: Double/long click - admin - 11-02-2022 now H32B not support double click directly. But we are designing new "switch terminal board" , will support this function in furture. RE: Double/long click - xray - 11-02-2022 (11-02-2022, 09:59 PM)admin Wrote: now H32B not support double click directly. But we are designing new "switch terminal board" , will support this function in furture. thanks. Anything indirectly? I'm planning to integrate the H32B with a Loxone miniserver Gen2. I also have a switch board. RE: Double/long click - admin - 11-03-2022 if you integrate to Loxone, you can make double-click function by Loxone mini server's software. H32B relay controller just do actions. RE: Double/long click - Sten - 11-03-2022 (11-02-2022, 09:59 PM)admin Wrote: now H32B not support double click directly. But we are designing new "switch terminal board" , will support this function in furture. Hi When it could be released? Regards Sten RE: Double/long click - admin - 11-03-2022 maybe after 2-3 weeks. |
