Digital input max voltage - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: Digital input max voltage (/showthread.php?tid=3114) |
Digital input max voltage - jeepxj - 08-02-2023 What is the voltage range for the digital inputs? I'm trying to use this in an automotive setting so it might see up to 18v at times. what about the main power input. is 12v really the max here? RE: Digital input max voltage - admin - 08-02-2023 which controller model you are using? RE: Digital input max voltage - jeepxj - 08-03-2023 (08-02-2023, 11:05 PM)admin Wrote: which controller model you are using? kc868-a6-v1.3 RE: Digital input max voltage - admin - 08-03-2023 0v or MAX12v for digital input port. RE: Digital input max voltage - jeepxj - 08-03-2023 (08-03-2023, 01:40 AM)admin Wrote: 0v or MAX12v for digital input port. ahh so 14.4 from a car will over volt. understood. will step it down to 3.3 RE: Digital input max voltage - admin - 08-03-2023 ok |
