KC868-H32B - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: KC868-H32B (/showthread.php?tid=426) |
KC868-H32B - juan - 08-12-2021 Hello everybody. First of all I apologize for my English as a translator, but I hope it is enough for me to be understood. I am configuring the integration of the KC868-H32B board to Home Assistant via Node-Red. To do this, I have followed the instructions in the video. https://www.youtube.com/watch?v=2UVbEHWuvo4&list=PLQUWhE_6LeOSgQcfv2UendJgZqNiwV92_&index=3 At the beginning, everything works perfectly, but only with the first 6 relays, from relay number 7 the Node-Red tcp out module is shown as not connected. I can't find where the problem is, can you guide me? Thank you very much in advance. RE: KC868-H32B - admin - 08-12-2021 because you have use "TCP OUT" node many times, one module MAX support 5 TCP clients. I suggest you use 1 "TCP OUT" node is enough, not need to use 6. if you using KC868-H32B, also can use MQTT node, that will be more easy and convenient. |
