KC868-HAv2 esphome issue - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Development (https://www.kincony.com/forum/forumdisplay.php?fid=4) +--- Thread: KC868-HAv2 esphome issue (/showthread.php?tid=5252) |
RE: KC868-HAv2 esphome issue - procet - 04-03-2024 hi, is it possible to send the status of the inputs and outputs of the hav2 at power on of the board? thank you RE: KC868-HAv2 esphome issue - admin - 04-03-2024 do you use home assistant ? RE: KC868-HAv2 esphome issue - procet - 04-04-2024 Exactly! RE: KC868-HAv2 esphome issue - procet - 04-24-2024 Hi! Any update? Thank you RE: KC868-HAv2 esphome issue - admin - 04-24-2024 HAv2 will not auto send command. need to read it. RE: KC868-HAv2 esphome issue - procet - 04-27-2024 Is it possible for you to modify the firmware so in the power-on procedure the board sends the status of all 6 inputs? RE: KC868-HAv2 esphome issue - admin - 04-28-2024 sorry, will not do that. if you can write STM32 C code, you can write your own code download to CPU. RE: KC868-HAv2 esphome issue - procet - 04-29-2024 Can you give me your source code so I can modify it? RE: KC868-HAv2 esphome issue - admin - 04-29-2024 this is not open source. you can write by yourself. RE: KC868-HAv2 esphome issue - procet - 04-30-2024 Ah, ok.. But in the homepage it says this: Quote:ABOUT OUR COMPANY |
