Contact mono stable - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: Contact mono stable (/showthread.php?tid=575) Pages:
1
2
Contact mono stable - gr électricité - 08-29-2021 Bonjour Comment puis-je avoir un contact mono stable sur le module KC868 s’il vous plaît ? Merci RE: Contact mono stable - admin - 08-29-2021 what's your means? RE: Contact mono stable - gr électricité - 08-30-2021 Je voudrais avoir un contact d’une seconde environ RE: Contact mono stable - gr électricité - 08-30-2021 Je voudrais temporiser le relais RE: Contact mono stable - admin - 08-31-2021 can you write in English? now i don't understand your words. RE: Contact mono stable - gr électricité - 08-31-2021 Yes, sorry, I'd like to have a one-second timed contact to create an impulse RE: Contact mono stable - admin - 08-31-2021 if you using KC868-H32B , just set in network webpage, there is a momentary time option can be set for 1-10000 second. RE: Contact mono stable - gr électricité - 08-31-2021 Ok, thanks, I'll watch that tonight RE: Contact mono stable - gr électricité - 08-31-2021 I don't have an H32B module but an H32L and in the web page I can't find a timer for relays RE: Contact mono stable - admin - 09-01-2021 if you use H32L, you can create scene mode in phone app, add action relay1 ON -> delay 1S -> relay1 OFF is ok. |
