A16 rs485 problem - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A16 (https://www.kincony.com/forum/forumdisplay.php?fid=25) +--- Thread: A16 rs485 problem (/showthread.php?tid=5933) |
A16 rs485 problem - Psix_anp - 06-19-2024 Hi! Help me pls for a16 not working relay after 8relay on rs485 - platform: modbus_controller name: 'modbus-switch2_1' address: 0 # 0:relay1 1:relay2 ...... register_type: coil bitmask: 1 - platform: modbus_controller name: 'modbus-switch2_2' address: 1 # 0:relay1 1:relay2 ...... register_type: coil bitmask: 1 - platform: modbus_controller name: 'modbus-switch2_3' address: 2 # 0:relay1 1:relay2 ...... register_type: coil bitmask: 1 - platform: modbus_controller name: 'modbus-switch2_4' address: 3 # 0:relay1 1:relay2 ...... register_type: coil bitmask: 1 - platform: modbus_controller name: 'modbus-switch2_5' address: 4 # 0:relay1 1:relay2 ...... register_type: coil bitmask: 1 - platform: modbus_controller name: 'modbus-switch2_6' address: 5 # 0:relay1 1:relay2 ...... register_type: coil bitmask: 1 - platform: modbus_controller name: 'modbus-switch2_7' address: 6 # 0:relay1 1:relay2 ...... register_type: coil bitmask: 1 - platform: modbus_controller name: 'modbus-switch2_8' address: 7 # 0:relay1 1:relay2 ...... register_type: coil bitmask: 1 - platform: modbus_controller name: 'modbus-switch2_9' address: 8 # 0:relay1 1:relay2 ...... register_type: coil bitmask: 1 - platform: modbus_controller name: 'modbus-switch2_10' address: 9 # 0:relay1 1:relay2 ...... register_type: coil bitmask: 1 - platform: modbus_controller name: 'modbus-switch2_11' address: 10 # 0:relay1 1:relay2 ...... register_type: coil bitmask: 1 - platform: modbus_controller name: 'modbus-switch2_12' address: 11 # 0:relay1 1:relay2 ...... register_type: coil bitmask: 1 - platform: modbus_controller name: 'modbus-switch2_13' address: 12 # 0:relay1 1:relay2 ...... register_type: coil bitmask: 1 - platform: modbus_controller name: 'modbus-switch2_14' address: 13 # 0:relay1 1:relay2 ...... register_type: coil bitmask: 1 - platform: modbus_controller name: 'modbus-switch2_15' address: 14 # 0:relay1 1:relay2 ...... register_type: coil bitmask: 1 - platform: modbus_controller name: 'modbus-switch2_16' address: 15 # 0:relay1 1:relay2 ...... register_type: coil bitmask: 1 address 10,11 etc not working I can switch only 8 relays? my hardware A16 RE: A16 rs485 problem - admin - 06-19-2024 do you use KCS firmware? if YES, which version you are using? RE: A16 rs485 problem - Psix_anp - 06-20-2024 Yes, v 1.0.24. First A16 working on esphome, second on kcs RE: A16 rs485 problem - admin - 06-20-2024 please use this newest V2 version, here is download link: https://www.kincony.com/forum/showthread.php?tid=3791 RE: A16 rs485 problem - Psix_anp - 06-20-2024 (06-20-2024, 09:50 AM)admin Wrote: please use this newest V2 version, here is download link: https://www.kincony.com/forum/showthread.php?tid=3791 binding input to output not working RE: A16 rs485 problem - admin - 06-20-2024 V2 firmware use IFTTT command for INPUT link with OUTPUT. my means, you can test V2 firmware, whether you can use modbus command for 9-16 channel output. RE: A16 rs485 problem - Psix_anp - 06-20-2024 (06-20-2024, 10:31 AM)admin Wrote: V2 firmware use IFTTT command for INPUT link with OUTPUT. my means, you can test V2 firmware, whether you can use modbus command for 9-16 channel output. OK RE: A16 rs485 problem - admin - 06-21-2024 i have checked with OUTPUT9 with modbus command, it's OK. can you take a photo how you connect wire with your A16 board? whether you have connect the RED wire as mine? RE: A16 rs485 problem - Psix_anp - 06-22-2024 Ok, i'm tomorrow send video RE: A16 rs485 problem - Psix_anp - 06-23-2024 Hi, v2 firmware also not working. What address 9-16 relay? - platform: modbus_controller name: 'modbus-switch2_13' address: 12 # 0:relay1 1:relay2 ...... register_type: coil bitmask: 1 Relay 13 - address 12? Or 0x0B? |
