Connecting Photoelectric (laser) meter - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A8 (https://www.kincony.com/forum/forumdisplay.php?fid=23) +--- Thread: Connecting Photoelectric (laser) meter (/showthread.php?tid=7248) |
Connecting Photoelectric (laser) meter - Killi77 - 12-20-2024 Hi, I'm looking for a solution connecting photo-electric (laser) distance meter to KC868-A8. Can I use ADC A1 or A2 port? I don't have the device yet so if you have any advice would be great otherwise I found the one in picture. Can I use this model with some resistor connected in serial to achieve 0-5V? Can you also provide ESP32 coding to configure those ports in Home Assistant please? Thank you. RE: Connecting Photoelectric (laser) meter - admin - 12-20-2024 the sensor output is BINARY SENSOR type, not analog output. you can connect to KC868-A8's digital input port. RE: Connecting Photoelectric (laser) meter - Killi77 - 12-21-2024 Contacting the supplier and he confirmed it is a sensor only. It says measuring distance but it is not measuring anything. They description is misleading. Thank you for giving me a heads up. Anyway, I need to measure the distance to a small moving point. Moving edge of garage door to be exact. Would you happen to know any solution? Device that can be used? Thank you. RE: Connecting Photoelectric (laser) meter - admin - 12-21-2024 you can search by Aliexpress. whether have some Ultrasonic ranging module. |
