KC-868-A4 0v-5v ADC no where near accurate - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A4 (https://www.kincony.com/forum/forumdisplay.php?fid=21) +--- Thread: KC-868-A4 0v-5v ADC no where near accurate (/showthread.php?tid=7361) |
KC-868-A4 0v-5v ADC no where near accurate - Fleetz - 01-13-2025 Connecting the 0-5v generator to the A3 or A4 the ADC is reporting considerably lower voltages than what is physically generated and measured using a multimeter. Also if program an event using IFTTT using the ADC voltage to switch a Digital output it will not trigger the event? E.G. IF AI3 is <=2.00v THEN DO1 to On if I reduce the voltage to AI3 to less than 2.00v or even drop it down to zero volts DI1 output does not change state. RE: KC-868-A4 0v-5v ADC no where near accurate - csacomani - 01-23-2025 Dear Fleetz, The ESP32's Analog to Digital Converter (ADC) has a resolution of 12 bits, which means it can detect 4096 analog levels. The ADC can convert input voltages between 0 and 3.3 volts into integer values between 0 and 4095. You are using custom values, so there is no positive result. RE: KC-868-A4 0v-5v ADC no where near accurate - Fleetz - 01-26-2025 Thanks for the reply. Given the ADC is 12 bit with 0-4096 and accepting that the range is 0 to 3.3v which I was aware of at the time of posting I would expect the accuracy of the KSC monitor from my 0-3v would be extremely close. However it is not. The bit table to voltage therefore can not be accurate. RE: KC-868-A4 0v-5v ADC no where near accurate - admin - 01-27-2025 what KCS firmware version you are using? after our new year holidays, i can test it. RE: KC-868-A4 0v-5v ADC no where near accurate - Fleetz - 01-27-2025 (01-27-2025, 12:57 AM)admin Wrote: what KCS firmware version you are using? Your version 2 RE: KC-868-A4 0v-5v ADC no where near accurate - admin - 01-27-2025 i need details, what firmware version, you can take a photo of KCS INDEX webpage. the webpage have showed the version. |
