Several controllers in one area - Printable Version
+--- Thread: Several controllers in one area (/showthread.php?tid=7637)
Several controllers in one area - peacemakerv - 02-17-2025
HI, All
I'm making testing 5 controllers at the same time in one room. Developing my own FW for ESP32, as before did and worked OK.
But i have found that if several my KC868-A6 boards (2...5pcs) are online (via single WiFi-router) - there are many transmission errors.
If to switch all off excepting one - no any errors at all ! Fully OK working with a server.
It is strange, i'm sure.
Is it known subject ? Any ideas why?
I need to use 3-4 pcs in some area of maybe 10 meter radius.
RE: Several controllers in one area - admin - 02-17-2025
i think it's problem with your router. you can replace router, or change the wifi channel of your router.
RE: Several controllers in one area - peacemakerv - 02-18-2025
(02-17-2025, 10:31 PM)admin Wrote: i think it's problem with your router. you can replace router, or change the wifi channel of your router.
YES! Thanks. Changing channel number from 3 to 12 helped a lot.
RE: Several controllers in one area - admin - 02-18-2025
ok, good.
