Trigger Outputs - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-HxB series Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=2) +--- Thread: Trigger Outputs (/showthread.php?tid=7760) |
Trigger Outputs - Error7 - 03-05-2025 On my KC868_A16 board, I'm trying to activate Output 1 when I trigger Input 1. I have set Output 1 as shown in my attached image but I can not get Output 1 to activate. RE: Trigger Outputs - admin - 03-06-2025 you should set by IFTTT webpage, not this page. here is KCS v2 online guide: https://www.kincony.com/esp32-kcsv2-firmware.html RE: Trigger Outputs - Error7 - 03-08-2025 I have used the IFTTT webpage to add what I think my settings should be. See the attached images. All I want to do is to switch the 12v DC Input to Output 1 when I activate Input 1. I am not able to do this. Can you please explain what I need to do to get it to work. RE: Trigger Outputs - admin - 03-09-2025 DI1=false THEN DO1=ON DI1=true THEN DO1=OFF try to test this. make two IFTTT command. RE: Trigger Outputs - Error7 - 03-09-2025 (03-09-2025, 12:55 AM)admin Wrote: DI1=false THEN DO1=ON Thank you, I finally managed to get it working. I think the instructions in your "how to use “KCS”v2 firmware" could be easier to understand. RE: Trigger Outputs - admin - 03-09-2025 ok, good. |
