KC868-A8 Error connecting to [AddrInfo(family=<AddressFamily.AF - Printable Version
+--- Thread: KC868-A8 Error connecting to [AddrInfo(family=<AddressFamily.AF (/showthread.php?tid=7840)
KC868-A8 Error connecting to [AddrInfo(family=<AddressFamily.AF - Rasim Shbitah - 03-20-2025
Salam Dears
I have this problem with  some boards in my project
I have  5 devices A8  each  device is connected to a switch server that connects us with the home assistant virtual machine using esphome
 if you have any solution  or  in code or my network
if you need  any information ask me
error code
INFO ESPHome 2025.3.0
INFO Reading configuration /config/esphome/hq3floor-a8-channel.yaml...
WARNING GPIO5 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Starting log output from 10.200.224.209 using esphome API
WARNING Can't connect to ESPHome API for hq3floor-a8-channel @ 10.200.224.209: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='10.200.224.209', port=6053))]: [Errno 113] Connect call failed ('10.200.224.209', 6053) (SocketAPIError)
INFO Trying to connect to hq3floor-a8-channel @ 10.200.224.209 in the background
this yaml  code
  friendly_name: HQ3Floor A8 Channel
esp32:
  board: esp32dev
  framework:
    type: arduino
  encryption:
    key: "**********************"
ota:
  - platform: esphome
    password: "************"
  sda: 4
  scl: 5
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 10.200.224.209
    gateway: 10.200.224.4
    subnet: 255.255.255.0
    dns1: 8.8.8.8
    dns2: 8.8.4.4
RE: KC868-A8 Error connecting to [AddrInfo(family=<AddressFamily.AF - admin - 03-20-2025
if you have many KC868-A8 board, i suggest you remove the static ip config code, just use by DHCP.
remove these code, connect to your router, DHCP by router is better.
manual_ip:
dns1: 8.8.8.8
dns2: 8.8.4.4
