24V Support - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: Suggestions and feedback on KinCony's products (https://www.kincony.com/forum/forumdisplay.php?fid=39) +--- Thread: 24V Support (/showthread.php?tid=7950) |
24V Support - yawniek - 04-18-2025 Hi, It would be good to be able to see more prominently which products support 24V input voltage and which products do not support it. Sometimes the board notes 12V but they work with 24V and sometimes not. Could you clarify which products support 24V and maybe put input voltage more clearly into descriptions? Thank You Y RE: 24V Support - admin - 04-19-2025 KinCony smart controller's digital input MAX voltage= power supply voltage. for exmaple, the board power is DC12V, so the digital input MAX is 12v. if the board power is DC24V, so the digital input MAX is 24v you can visit Product Selection System at here: https://mq.kincony.com/qq/product/product-selector set the "Power Supply" = "DC12-24V" , then submit, right window will list all products that can use by DC24V power, so that digital input can use for 24V DC. RE: 24V Support - yawniek - 04-22-2025 very cool, i did not saw this page before. thank you! |
