LCD i2s display on KS868-A16 - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-A series and Uair Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=6) +--- Thread: LCD i2s display on KS868-A16 (/showthread.php?tid=8034) |
LCD i2s display on KS868-A16 - markuutgrunnen - 04-30-2025 Hello, Who can help me, I have a KS868-A16 I would likeĀ to connect an I2s display 20x4) and show DS16B20 sensors on theĀ display but I can't do it. i use esphome, I have some DS16B20 sensors and they already work well with KS868-A16. Greetings Mark RE: LCD i2s display on KS868-A16 - admin - 05-01-2025 i suggest you chose KC868-A16v3, just donwload KCS v3 firmware, will support DS18B20 sensor showed on LCD directly. if you want to use KC868-A16 board, you can add SSD1306 display, that support by ESPHome, you can config by yaml file. RE: LCD i2s display on KS868-A16 - markuutgrunnen - 05-01-2025 (05-01-2025, 12:24 AM)admin Wrote: i suggest you chose KC868-A16v3, just donwload KCS v3 firmware, will support DS18B20 sensor showed on LCD directly.I want to connect a 20x4 LCD screen, can someone help me with the correct code?.
RE: LCD i2s display on KS868-A16 - admin - 05-01-2025 that need so much gpio, now KC868-A16 board no free gpio can use for that. RE: LCD i2s display on KS868-A16 - markuutgrunnen - 05-04-2025 (05-01-2025, 10:43 PM)admin Wrote: that need so much gpio, now KC868-A16 board no free gpio can use for that. why not gpio enough?, I use an i2c module that uses one GPIO!. RE: LCD i2s display on KS868-A16 - admin - 05-04-2025 you can chose whether esphome support that, or you can write your own arduino code to drive it. |
