How to use A6V3 with a momentary switch - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=20) +--- Forum: KC868-A6 (https://www.kincony.com/forum/forumdisplay.php?fid=22) +--- Thread: How to use A6V3 with a momentary switch (/showthread.php?tid=8042) |
How to use A6V3 with a momentary switch - Smithgrind - 05-02-2025 Hi, i bought a KC868 A6V3. I'd like to control the relays with a momentary switch. How can i do this? (I'm using KCS V3) RE: How to use A6V3 with a momentary switch - twostar - 05-03-2025 You can set up an IFTTT rule that's triggered by the input that the switch is connected to and sets the required output(s). RE: How to use A6V3 with a momentary switch - reehanlambe - 05-27-2025 Hi I bought new a6v3 when connected power all led on and off then I try to access but not able to access not even in network WiFi please guid RE: How to use A6V3 with a momentary switch - admin - 05-27-2025 please download KCS v3 firmware by USB-C cable firstly. new board no KCS firmware inside of ESP32. |
