ESP32-S3 Core Board - Resetting when Connecting/Disconnecting USB Serial Cable - Printable Version
+--- Forum: Development (https://www.kincony.com/forum/forumdisplay.php?fid=4)
+--- Thread: ESP32-S3 Core Board - Resetting when Connecting/Disconnecting USB Serial Cable (/showthread.php?tid=8084)
ESP32-S3 Core Board - Resetting when Connecting/Disconnecting USB Serial Cable - egionet - 05-16-2025
Has anyone else experienced the following behaviour with the ESP32-S3 Core Board:
  1. Connect the ESP32-S3 Core Board to the development PC via a USB serial cable.
  2. Compile the program and upload the binary to the ESP32-S3 Core Board.
  3. Observation #1: If the development PC is left connected for 2 to 3 hours, the ESP32-S3 Core Board reboots or it goes into an inoperable state that requires a hard reset.
  4. Observation #2: If the USB serial port's connection is cycled, from connected to disconnected, and then reconnected a couple of times, the ESP32-S3 Core Board reboots.
  5. Observation #3: If the USB serial cable is disconnected, the ESP32-S3 Core Board operates flawlessly.  The ESP32-S3 Core Board was left powered for a 7-day burn-in with no reboots or memory leaks.
Thanks in advance.
RE: ESP32-S3 Core Board - Resetting when Connecting/Disconnecting USB Serial Cable - admin - 05-17-2025
do you use your own arduino code?
RE: ESP32-S3 Core Board - Resetting when Connecting/Disconnecting USB Serial Cable - egionet - 05-17-2025
(05-17-2025, 12:16 AM)admin Wrote: do you use your own arduino code?
I use PlatformIO and the esp-idf framework (espressif32 platform).  This behaviour occurs when a basic program is uploaded, and it doesn't happen when I upload the same code to a standard 44-pin ESP32-S3 WROOM development board.
maybe you can send me one BIN file, we can download to ESP32S3, power on ,test for somedays, check whether will reboot.
RE: ESP32-S3 Core Board - Resetting when Connecting/Disconnecting USB Serial Cable - egionet - 05-20-2025
(05-17-2025, 11:46 AM)admin Wrote: maybe you can send me one BIN file, we can download to ESP32S3, power on ,test for somedays, check whether will reboot.
I plan to buy another ESP32-S3 Core Board for another device I am working on.  My existing ESP32-S3 Core Board is in use and not easily accessible for conducting tests.  Once I have another board, I will be able to run more tests.  If Kincony would like to donate one, it would be greatly appreciated.
  Big Grin
RE: ESP32-S3 Core Board - Resetting when Connecting/Disconnecting USB Serial Cable - admin - 05-20-2025
sorry, you can order online directly, any question you can leave message at here.
