R503 do'nt scan fingerprints - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=1) +--- Forum: KC868-A series and Uair Smart Controller (https://www.kincony.com/forum/forumdisplay.php?fid=6) +--- Thread: R503 do'nt scan fingerprints (/showthread.php?tid=8187) |
R503 do'nt scan fingerprints - remiasz - 06-13-2025 Fingerprint sensor R503 do not scan finger. I use KC868-A16 with ESPHome. Sensor is connected to HT1/2 port as Uart. I can control aura led but I get only "No touch sensing" message. "Wakeup" signal connected to HT3 all time is OFF. When I send command to enroll "Wakeup" goes to ON but sensor dont scan any finger. Can anyone help? RE: R503 do'nt scan fingerprints - admin - 06-15-2025 HT1/2 are 1-wire port, connect with 1-wire sensor, such as DS18B20. Because it have pull up resistance on pcb. if you want use as UART, need remove it. RE: R503 do'nt scan fingerprints - remiasz - 06-15-2025 UART on HT1/2 is working. I can communicate with R503 and control aura led. What pins can I use on UART if not HT1/2? I used HT1/2 as UART sooner with RFID reader and it was worked. RE: R503 do'nt scan fingerprints - admin - 06-16-2025 actually KC868-A16 no free GPIOs. RE: R503 do'nt scan fingerprints - remiasz - 06-16-2025 You were right. I connected R503 to S3 Super Mini module and it started reading fingerprints. Pulling to 3V disrupts UART operation? Thanks for advise RE: R503 do'nt scan fingerprints - admin - 06-17-2025 Pulling to 3V disrupts UART operation? Yes |
