KC868-AG gpio usage - Printable Version
+--- Forum: KC868-AG / AG Pro / AG8 / Z1 (https://www.kincony.com/forum/forumdisplay.php?fid=30)
+--- Thread: KC868-AG gpio usage (/showthread.php?tid=8272)
KC868-AG gpio usage - Ditchdigger - 06-26-2025
I recently received a kc868-ag unit and have successfully learned an ir key fob and transmitted, (via the KCS device webserver), the learned ir signal to the device being controlled. I would like to use the onboard gpio pins to enable a couple of the esp inputs to work via some dry contacts we have on our solar/inverter to start/stop our small propane generator with the ir signals. How to utilize the onboard free gpio's via the KCS webserver on the device? I don't see the option for Inputs, Outputs in the Index menu. Online, it shows the input and outputs at the webserver index. Perhaps I have to use another means to program the io's? I have installed the pins for the 16 gpio items on the board and would like to take a couple wires out to the inverter generator start contacts.
Thanks in Advance for your thoughts!, Matt
[Image: attachment.php?aid=7903]
RE: KC868-AG gpio usage - admin - 06-27-2025
already repied in another thread.
