Electric heated floor + F16. - Printable Version +- Smart Home Automation Forum (https://www.kincony.com/forum) +-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=62) +--- Forum: F16 (https://www.kincony.com/forum/forumdisplay.php?fid=63) +--- Thread: Electric heated floor + F16. (/showthread.php?tid=8321) |
Electric heated floor + F16. - skench - 07-17-2025 I have a kinocny F16. Please tell me, I don't understand how to connect a heated floor and a thermostat to this controller to control an electric heated floor? Can you draw a simple diagram to understand the connection? And also a question, I have 10 KinCony TS Tiny RS485 SHT30 coming to me, will I be able to connect everything to one F16 controller? I'm going to use KSC v3 to control the heated floor and KinCony TS Tiny RS485 SHT30 sensors. Thansk for you support and very nice product. RE: Electric heated floor + F16. - admin - 07-17-2025 1. do your heated floor and a thermostat control way by ON/OFF? if YES, just use by relay output. 2. sure, one F16 use by KCS v3, support MAX 254pcs of KinCony TS sensors. you can connect with all TS sensors together via RS485 bus. RE: Electric heated floor + F16. - skench - 07-17-2025 1) I am buy https://sl.aliexpress.ru/p?key=rouF3bd. Will I be able to control the thermostat + heated floor with this or do I need the simplest one? 2) Thanks RE: Electric heated floor + F16. - admin - 07-18-2025 our firmware not support this product directly. if you want to control it , you can try to config by esphome using modbus protocol. RE: Electric heated floor + F16. - skench - 07-18-2025 (07-18-2025, 12:41 AM)admin Wrote: our firmware not support this product directly. if you want to control it , you can try to config by esphome using modbus protocol. Thanks, I needed the answer, I'll just use simple thermostats like this one so I don't have to experiment with the settings. |
