KinCony G1 - RS485 with expansion card - Printable Version
+-- Forum: Technical Support (https://www.kincony.com/forum/forumdisplay.php?fid=66)
+--- Forum: G1 (https://www.kincony.com/forum/forumdisplay.php?fid=67)
+--- Thread: KinCony G1 - RS485 with expansion card (/showthread.php?tid=8422)
KinCony G1 - RS485 with expansion card - SixSixOne - 08-06-2025
I've received a G1 device and my intention is to connect it with an RS485 IO expansion card 16In - 16Out (Maker: Eletechsup // N4D2E16).
The issue is that although I can send commands to the card and enable the Outputs by using custom RS485 protocol and IFTTT command (from the DI of the G1 board), I cannot receive info from N4D2E16 Inputs to the G1 in order to use them in Home Assistant.
How can I see the inputs of the board as well?
Tks
SSO
RE: KinCony G1 - RS485 with expansion card - admin - 08-06-2025
whether can send / receive without your "RS485 IO expansion card"? if work well, maybe not compatible with your card.
RE: KinCony G1 - RS485 with expansion card - SixSixOne - 08-07-2025
(08-06-2025, 11:54 PM)admin Wrote: whether can send / receive without your "RS485 IO expansion card"? if work well, maybe not compatible with your card.
It seems that G1 is working properly but I do not know how to "read" data from any RS485 unit. Could you please assist? I'm using the latest firmware.
Tks
Dimitris
RE: KinCony G1 - RS485 with expansion card - admin - 08-07-2025
if you use kincony KCS firmware, RS485 only use for kincony's product, such as KinCony TS RS485 temperature sensor.
